Ez Line Chart icon Ez Line Chart — 4-series historical line chart to log and compare robot sensor values over time with customizable titles, colors, time axis and EZ-Script control Try it →
Your IP address.... 192.168.1.7.6666. Where did you get that from?
Same error with mine, I guess it may be a bug in the software?
Ireland
Thats the ip address and server port of the pc thats connected to the EZb
I should remove that video. The connection feature is no longer supported. We had to remove it because it was getting impossible to support with all the new v4 features.
To connect remotely, open a port in your firewall and connect to the robot. Otherwise, use the http server. We are also working on the ability to add your own HTML files to it. So that will allow greater customization and deprecate the need for remote ARC connectivity.
Ireland
thanks DJ no problem that its not supported my goal was to connect from the web and was using the wifi to carry out a local test first Pat :P
