Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
Weight Limits For Ez Bits
Hi,
I see that the weight limits for the Heavy Duty servo (HDS) is 15 kg but I would like to know how much weight could the Ezbit Adapt > HDS > Extension block > HDS >extension block > HDS > extension block > iron fist. :)
I'm wanting to see how easy it would be to control an AirWheel (electric self balancing unicycle) with the EzB as a potential robotic platform.
The AirWheel is steered with shifting weight in the direction one leans.
Thanks much mates!
Happy holidays!
Bill
I tried one of these airwheels once. If you don't mind me asking, how many times did you break your nose when it flipped?:D
I would suggest adding some sort of metal bars close to the floor. That way when it flips it doesn't break the robot.
Trinidad/Tobago
Twitter YouTube
have you tried using two separate arms, one for the front of the wheel and the other for the back? you might be able to achieve a better weight distribution that way.
Hey Sudo,
Only crashed once while looking sideways trying to read my rated speed in a digital sign. Scrached knee only.
Putting a servo arm on the side would make it move forward and backward more efficient but turning would could be more of a challenge. However opposing pendulum motions on each of these ends could make it twist. HHHHmmmm...
I followed Dave's suggestion and powered the servos independently of the EZb per this diagram below:
The servos were much more responsive and browned out less but it still seemd to draw too much current from the 12 v 1A power supply causing the Ezb to reset.
I'm going to scrap this idea for my laundry cart bot for a more practicle 6 wheel machine. It'll be two wheelchair motors in the center with 4 swivel wheels on the corners. I'm using a high tech looking full tower computer case for the base. I'll be posting updates on this thread: synthiam.com/Community/Questions/6788
Thanks so much for all your support.
You guys are awsome! Bill
