Wowwee MIP Movement Panel icon Wowwee MIP Movement Panel — UART-based EZ-B/ESP32 skill to control WowWee MIP, enabling ESP32-Cam camera support and flexible battery-powered integration. Try it →
Welcome To The EZ-B
Hello!
Welcome to the forum for the EZ-B Bluetooth Hobbyist Robot Controller. This forum is for the present and future EZ-B community users to discuss projects and ask questions. We have tried to make this website informative and easy to understand. It is our goal to ensure you have positive experiences with the EZ-B, ARC and the EZ-SDK.
Thank you winstn60,
Thanks for the response. Yes, the utilities drop down menu where it says hardware status led on/off works when I select off the white led goes off, and on the white led is lit on the EZ-B. The servo I am testing on digital slot DO has the black wire facing the outside of board. I currently have ARC version 11 installed (I tried cross referencing here on the release notes but it only has release dates but not the version number). Is there another version? I do not know why it is not working when I test the servo after configuring. Is there any other suggestion? Am I missing something?
Again thanks for the help,
Leo
Hey there Baldeagle!
The servo is connected backward. The pins are labelled GND, +5, Signal from inside to out. The balck wire will be GND and should be facing inside of the board.:)
OK now thats embarrassing :) It works great !! I'll be honest I automatically assumed the ground was to the outside of the board because of many servo controllers I have used in the past. My bad, never assume. I can't wait to dig deeper into this board and I'm sure I will have many questions throughout my build.
Thank you,
Leo
At least nothing got fried (save for your ego) when you plugged the servos in wrong. I did the same thing with my first Pololu dual motor driver and it fried both the logic and the driver chips in about 2 seconds flat - yes, as in big puff of smoke. It probably would have been ok had I been using the EZ-B for power (5V) but I was using an external 12V supply.
Whenever I do something stupid like that I always think of my brother-in-law's motto (he's a carpenter): "measure twice, cut once"...
I have fried one of my ADC channels on my EZ-B board by connecting it straight to the supply battery!! not clever. Still I have loads more left to play with
A mechanics motto "tighten the nut until it snaps and then back it off half a turn" :)
Ouch on frying your EZ-B. The EZ-B can have separate power for servo's correct?
I have a logitech joystick that I was configuring and must say I am really impressed on how easy it is to configure the joystick buttons in ARC however I would like to go wireless and use a PS3 bluetooth game remote for controlling the EZ-B.
Does anyone know how it can be done? Can the PS3 bluetooth game remote work with EZ-B? If so what would be the necessary steps? Do I have to download additional programs?
As always thanks for the help
Well I only fried one channel everything else works ok
I use a PS3 joystick but not via bluetooth. The drivers to use the PS3 Joystick with a PC with a cable were released recently on the net but I haven't seen a bluetooth set of drivers as yet
There are other Bluetooth/wireless joysticks you can use
