Getrss icon Getrss — Fetch RSS via GetRSS command; populates $RSSSuccess, $RSSErrorMsg and arrays $RSSTitles, $RSSDescriptions, $RSSLinks, $RSSDates for scripts. Try it →
That's brilliant!
i have a plastic welder kinda like that ,but uses air too and plastic welding rods air plastic welder it also has adjusted heat
best plastic welder is utrasonic welder machine like the branson ,but then you are looking at $10000 just the utrasonic transducer is about $1000 and the horns are another $300 to $800 very high voltage transducers i have to repair them at work alot
Awesome..thanks Herr Ball..I have a dremel tool which should do the same thing:)
