Display Popup icon Display Popup — Full-screen popup display for ARC: show custom text with configurable timeout, font, text/background color, size and position via controlCommand(). Try it →
#17
Yes I have the same question
  1. Have a lap top and it seems to have a hard time running
#18
@David what's your machines specs and are you running win 7? I've found Win 7 has been the best even when running on older machines like 1.78ghz CPU and 512 mb ram , I still get a better experience than with xp.
#19
Josh, I don't know too much about this. I have a little 10" Acer Netbook that I was given. It was upgraded to Windows 7. It has an Atom 270 processor, 1.6GHZ. I tried Ez-B on it. It works all except the camera tracking gets lost. Right now it only has one gig of ram. It can be upgraded to four. Is it worth upgrading? Will that be sufficient for EZ-B? I would like to put it on board. The small size will be convenient. Thanks.
#20
What OS is it @Danger!
Windows 7 32 bit can have up to 4Gb (3.25 usable) Windows 7 Starter is limited to I believe 4Gb from the top of my head, it may be 2Gb 64 Bit allows for more, depending on the OS.
Windows 7 Ultimate 64 Bit can use more memory than is physically possible to install.
It also depends on the motherboard and how much it can take. Crucial have a great tool to tell you what you can and can't do. You needn't buy their brand of ram to use the tool either.
As much as possible is the answer. 4Gb should make it work great going by the information to hand. My 2Gb HP laptop works fine but 4Gb would make it better than fine... Fine isn't good enough for me but that's me:)
#21
@danger , your netbook is upgradable to 2gb , you must replace the chips already there which are two 512mb. You will need to dissasemble the netbook to get to the second chip under the keyboard. This will help a bit , also you NEED to download drivers and graphics accelerators. I believe that netbook has a intel 945 graphics chip set and when processing video this is used a lot , if it is not installed or the Intel graphics accelerator is not on the performance is poor. There is a great driver and Accelerator for them. I believe it made the clock for graphics run at 400mhz instead of 233 , a good performance increase.
#23
This is GMA Booster , brings the clock up to the chipsets default 400mhz from 233 , I used this and was able to play Wow on a netbook at 10-15 frames , DJ is taking advantage of the graphics processor to process the video which is more efficient use of your Pc hardware. https://www.gmabooster.com/download_win.htm
#24
You can disable certain features of win 7 like shadows , transparency , AERO , and things like that can add performance. Also uninstall ARC and reinstall after you make the changes I suggested;) do the diver updates and media accelerator and try again and tell me if it fixes your problem.
