Darknet YOLO (Obj Detection) icon Darknet YOLO (Obj Detection) — Tiny YOLOv3 CPU-only real-time object detection using a camera; offline detection, script-triggered on-changes or on-demand results with class/scores. Try it →
Resolved Resolved by Robot Doc!
What End Is This?
What End Is This?
What has the end of this battery?
www.ebay.com/itm/Auction9-Rechargeable-8000mAh-li-ion-Battery-Large-Capacity-DC-12V-SSY-2227/400639055963?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D3951482667192539355%26pid%3D100011%26prg%3D1005%26rk%3D2%26rkt%3D5%26sd%3D251416840547%26
It would appear that the battery has dual 2.1 or 2.5mm dc connections. One jack is used to connect to the EZ-B, and the other is where the charger connects to.
I guess ill buy this end for the ez-b. Will wire a mini dean to the connector.
Or just wire a mini deans directly to the battery itself... cut the barrel plug off the battery and solder a mini deans to it...
Doesn't the V4 come with an adapter? I'm sure I read it does...
