Tutorial icon Tutorial — Tutorial slide plugin for ARC: create, format and embed text and images per .ezb project; navigate/update slides via ControlCommand; auto-resize images Try it →
You might want to get some servo Extention cables if you think you will need more than 10-12 inches to hook the EZB to the servos on the robot. Also, a good dremel type tool would be good to have.
Always get servo extension cables, they are the one thing I forgot and the one thing I need more than anything else now.
Lots of hot glue, epoxy etc.
Dremel (or similar) tool
Soldering iron, solder, flux, tip tinner etc.
Drill, drill bits etc.
Cutters, wire strippers, various screw drivers.
Lots and lots of batteries or an external power supply
