Indoor Positioning System icon Indoor Positioning System — Infrared indoor positioning for ARC robots: dual-camera tracks IR beacon, shows real-time heading, path and EZ-Script navigation variables Try it →
What If There Was An Ezb Pro? What Would It Have?
Ok this is just to kick around ideas but what if you could buy a ready to go kit to trick out your EZB V3? I have a few ideas myself but I want feedback
1.-Built in wifi 2.4 ghz option for long range / networking
2.-a plexiglass case consisting of a base 1/4" plexi, standoffs and 1/4" plexi cover to protect ezb and wiring
3.-a servo wire loom organizer , somthing simple to clean up wiring
4.-lighting in the baseplate of plexi surrounding ezb in a square halo of blue (or other) light
5.-a 2200mah or 5000mah lipo battery to power ezb and servos instead of AA batteries , complete with Y harness for easy charging or rigging your externsl charger
6.-a high current 6v power board for high torque servos that easily connects to the case as a module. Get the full potential of a servo at 6v high current rather than 5v and lower current.
7.-a small fan probably a slimline and QUIET 6v or 12v to keep air running accross the heat sinks built into the EZB Pro mounting plate for a cool and happy EZB
8.-ability to add on a small Darlington Transistor board to operate high current items like LED arrays , Bright lights , relays, ect and mount to either side of the EZB pro case or mounted separate. This would have between 4 and 8 transistors for turning items on.
9.- Reset Switch - to easily power EZB on or off to pair or just kill the power other than pulling connections loose.
10.- Status lcd maybe? Ive seen them for arduino and they can show many things , like battery level , voltage , the scripts being ran , errors ect.
11.- 2 USB plugs - for powering a camera and other 5v usb electronics
  1. Maybe EZB Pro kit could have like 6 High Torque Servos 240 oz in @6v
  2. EZB pro kit could have the option of getting a l298n 2.5a or 12a Sabertooth included
14.Heavy Duty servo LONG ext cables with thicker gauge wire to support the demands of high Torque servos that can draw 5 to 7 amps each lengths of around 300mm and 500mm assortment.
Not sure where in Wisconsin you live Dave but it seems the whole state is -35F ...Stay warm Dave both outside and inside the house!
ClassMaximum PowerOperating Range Class 1100mW (20dBm)100 meters Class 22.5mW (4dBm)10 meters Class 31mW (0dBm)1 meter
wifi ,Josh? or bluetooth?:)
Just revisiting this thread , DJ , Alan and the staff implemented most of our suggestions in the EZB V4 , awesome right? , Props guys - Josh
Great minds think alike.:D
#16
That's what set's you apart from the rest, you listen and you provide pretty much anything we ask for:)
One thing that keeps cropping up and I don't think has been sorted is an external power board for 6v servos. Are things like this (and TIP120, Battery Monitors/Voltage Dividers etc.) also part of the revolution/coming soon/planned for future? I have some board prototypes designed (although not built or tested yet) but if these things are coming then I'll hold off on those boards and use EZ-Robot ones. Otherwise I'll throw the board designs and schematics out there for discussion, fine tuning and testing.
