EZMQTT Broker icon EZMQTT Broker — Local MQTT broker for ARC: host pub/sub messaging on TCP port 1883, relay topics between publisher and subscriber clients. Try it →
What Is A Good Omnidirectional Microphone To Use On The Robot
I will be using an on board Mini ITX mb. for autonomous operations. Normally I will be using a Bluetooth microphone whenever giving specific commands to the robot. However, what would be a good brand of omnidirectional microphone to use (mount) on the robot so it can hear clearly when others speak to it or ask it questions? I would like to find one for under $50. Does anyone have any suggestions?
Rex, I've been struggling with this also. I've found that mounting the mic on the robot is a problem. It will pick up the motor noise and the SR wont work well. I want to find a wireless mic that can sit away from the robot and send signals to an on board ITX. Sadly this is getting away from what we both want to do but the robot noise wont let the SR work.
How about putting some sound deafening foam ? Just a suggestion
I would really advise against any kind of remote mic (by that I mean any mic that's not within a foot of your mouth) for any kind of voice recognition. I've tried a few and so far background noise is always an issue. Currently I use the Kinect mic array which is supposed to be really good and it isn't... dictation is very poor.
I'm just about to risk losing bluetooth connection to the EZ-B by attempting to connect a PS3/phone BT headset to my PC... As far as I'm concerned this is the only low cost reliable way. (Wish me luck!..)
Spain
I have seen in "RoboCup-Home" using a long microphones of verbal orders, maybe use a gain attenuator between the microphone and the pc to suppress background noise.
I have a couple of these. They are optimized to catch both right and left side and each individual mic is removable and can be extended to have one mic on each side of your robot. Then its combined into one signal. They are Sony condenser mic about 7 dollars on eBay.
I've been using the Blue Snowball and have had fairly good results. of course accuracy is best when it's quite It's attached to the laptop with USB and about 6 feet away from the robot.
