i get an error trying to use the ping sensor.something about matrix is not good.
and the text is in nederlands written
bigger pic
UBTECH Alpha Servos UBT-12HC
— Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping.
bigger pic
@Richard.
I've never been able to copy or paste script to and from ARC using a mouse or trackpad.
@Steve Hmmm, that's weird... You're right... I pretty much use ctrl + C, V, X exclusively so I had never noticed right clicking doesn't work in ARC scripts
@Richard.
Yeah, that's never worked. Well there's your "new thing I Iearned today".
mine doesn copie eather.so here printscreen.
whits i wanne try is the ping make sound i have on pc(sonar) and when he detects some say danger,danger,danger also sound file i have.
Shouldn't there be an "If" and "EndIf" code in there, like "if ping is lower than 50, do or say this"?
i dont know anything about scripting.
@Nomad... Does your ping work and is it attached to ports D22, D21 when you run the script?
rr
yes and i checked the volt regulator too.
