Wheel Encoder Counter icon Wheel Encoder Counter — Arduino UNO wheel encoder: reads left/right ticks, provides counts, configurable ticks, wheel & pivot sizes, optional pose telemetry to ARC NMS. Try it →
I'm having good luck with the USB connected Blue Snowball. It has 3 different settings for sound detection.
Thanks guys, got a basic desktop mic (3.5mm jack).... Seems to work well with Windows 7 speech rec and my CF-19... Have to wait to get my EZB to see if it will be good enough for ARC....
If it works with Windows speech recognition then it'll be great with ARC.
Also, you can test it in ARC before getting the EZ-B. Just play with the SR settings and commands, an EZ-B and servo do not need to be connected for the speech recognition control and scripts to make a servo control move:)
You could make a project with a simple Digital Switch set for D0 Add speech recognition and set up the phrase "turn on" to run the script command
Set(D0, on)
and "turn off" to run the script command
Set(D0, off)
The speech should make the control turn from red to green when turning on and green to red when turning off.
Ignore the debug messages though:)
Yep, it works Rich... only 2 months to try it out now...:)
