DHT11 Temp & Humidity Sensor icon DHT11 Temp & Humidity Sensor — Read DHT11 temperature and humidity on Arduino (signal pin 4) using EZ-Genuino_DTH11_Uno firmware; exposes $Temp and $Humid variables. Try it →
Pretty much, the main differences are that the robie has a different head.
What features are you hoping to add to it?
The Robie Sr is basically a Hearoid as far as the bits we use are concerned, feel free to have a look at Melvin for ideas and to judge if you want to use the Robie or go for a 5402.
Holland
I want to know if he does random things in the house like a pet
If you add the EZ-B, sensors and servos and program it to then yes.
Holland
Is it very difficult to to make your robot
The EZ-B makes it all very easy. The hardest part is the physical modification to the old toy robot and then even that's not too difficult. It all depends on what you do mind you, some things are trickier than others but the EZ-B side and ARC side of it is very easy, and if you get stuck this community is always there to help you out.
Holland
Ok thanks for your hel
@Lars this is the number 1 place I've seen for customizing Omnibot toys into modern robot pets.
