Command Duplicator icon Command Duplicator — Duplicate and synchronize commands from one master EZ-B to multiple slave EZ-Bs for simultaneous, mirrored robot actions. Try it →
Wheeler chair robot
Wheeler Chair Robot
I saw that last year somebody had built a wheel chair robot?. My idea for the new Robot will be as a stage mascot that can also pretend to play the drums on stage. My brother has a live Metal band every Saturday night and most of the time we have trouble with no drummer showing up. We end up using a Drum machine instead with the 2 other guys on real guitars and singing. So Terminator will be able to move around and substitute behind the drum kit with the Live drum machine signal activating terminator arms at the drums. Also need him to move around in a wheel chair , so is anyone out there that has done this wheel chair hack, looking for suggestions on power/motor controller connections etc...should not be too hard just larger than I'm used to building. This is a youtuber that bought what I just bought,takes a month to get from China and we are building the rest of the Endoskeleton to integrate in wheel chair....
#585
Ya looks like every servo i put backwards, following the Instructions on 6 basic build 1 more leg to go.They go together so tight.
#586
Well it is working ,walks perfectly,all good now just need to put blue dome back on and fit the RGB and Sonar.Thanks again Nomad!
yeach six stepped into 2021 .greatxD
#588
The replicators are here! You all will be replaced by replicated copies,ha ha:p
Here is the fastest one  :-)
Mr. Spider Sapian meets Spider Bot
EzAng
hehe thats a spider on steroids .
#591
God damned creepiest robot I have ever owned now! Testing had 1 servo that was not working,was just the pin connection loose on EZB, now working 100 percent again,there is a list of all these dance moves and attack moves that I guess DJ added all those in the synthiam ARC 6 program. This is just wow more awesome than watching a Roomba vacuuming!:D
roborad
good find about the pin . how is the sound ?
