Movement Script icon Movement Script — Trigger direction-specific scripts when ARC movement panels change; assign scripts per direction/stop, access direction and speed (JS/Python/EZ). Try it →
When Using Dynamixels, ARC Has A Tendency To Move Servos In The Wrong Ord
whenever I try to move my (upcoming) humanoid, sometimes ARC will move completely different servos or not finish the movement before continuing on. I don't know if this is because of the dynamixel speed bug or something else, but it happens more often when the EZ-B has to move a larger amount of servos (about 6 or so seems to really screw up stuff) whatever is happening seems to happen even worse when running off of a slower computer (like my surface).
just to let you know, my humanoid IS running off of a 12v battery pack and has newly replaced servos. I don't this is a problem on the robot's end.
It's been a problem with the dynamixel itself - not ARC. Something I have been wrestling with for a while. It has to do with their communication protocol attempting to write a response while other commands are being written to other servo addresses - I beleive. I have included a "disable response messages" in a few ARC.releases ago, but that hasn't seem to have an effect.
This upcoming week I will be releasing a newer version with another change that hopefully overcomes this issue
thanks DJ, i didn't know that it was a known issue:D
Also DJ- my dynamixels are having trouble pushing up the robot, but I know for a fact that these servos are more than powerful enough to complete a pushup for half of a robot. Does this have to do with that communication problem or could it be i have another faulty servo?
It would not be from the bug. Its less of a bug and more of a design flaw overlooked in the servos. Do not consider it a bug:) it's how their communication protocol works. I'll over come it soon:D
