Darknet YOLO (Obj Detection) icon Darknet YOLO (Obj Detection) — Tiny YOLOv3 CPU-only real-time object detection using a camera; offline detection, script-triggered on-changes or on-demand results with class/scores. Try it →
#1   — Edited
I see you have selected an ezrobot iotiny as hardware to use with Synthiam ARC software. A good place to begin is visiting the manufacturers website and following their tutorials in their support/learn section. Their website is www.ez-robot.com
once you get some details about the ezrobot product that you selected, a good place to start using Synthiam’s ARC software is the support section that has getting started tutorials.
access the support section to find the getting started guide by clicking SUPPORT from the top menu of this website
Hi MartyK
EZ-Builder is now called ARC.
#3   — Edited
As Jeremie said -  you can download ARC here: https://synthiam.com/Products/ARC
Or, you can click PRODUCTS -> ARC from the top menu of this website
PS, please comment on related topics or create a new topic. Your original post was on the MQTT client skill. I moved it here.
#4   — Edited
For sure... the manual for your product is on the manufacturers website. In this case, the manufacturer is www.ez-robot.com
you can change the IP address of either your router or the iotiny. Here’s a link to the relevant manual page from the manufacture that will help you: https://synthiam.com/Tutorials/Lesson/80?courseId=4
there’s a lot of getting started tutorials on ezrobot website for that product. Good place to start:)
Portugal
#5   — Edited
It is just 192.168.1.1 you can use a wifi dongle to connect directly to ezb
#7   — Edited
When you connect to the iotiny over wifi, what IP address are you assigned?
check using the cmd prompt and type ipconfig.exe
Would be helpful if you pasted a screenshot using Windows snippet tool here. So I can see the ip configuration of the cmd.exe ipconfig.exe
Did you try to reset the IoTiny to it default AP mode and start the setup process over to get it into WiFI mode? This usually helps. Look for the location of the reset button below:
