Continuous Servo Movement Panel icon Continuous Servo Movement Panel — Control two continuous servos for bidirectional robot movement with speed sliders, configurable ports/stop values, testing and brake/coast options. Try it →
Well, you can make it connect to your router as well - but you won't know how to do that until tomorrow:)
Great ! That will give me time to hook up some goodies to the EZB4. I got the CPU temp and voltage display up and working with one click. The IP connection is really quick. And the connect and disconnect sounds are cool.
I'm somewhat up and running. I've been able to connect direct via PC and Mobile.
When I switch to client mode it gives me a "I have connected to your network"
but that's about it so far.
I scan to find it but it does not locate it.
Might be my router. It can be finnicky at times.
The following is purely based on assumptions and should only be used for additional guidance. I am not responsible for any inaccuracies due to the following. At this time I do not have a V4 in my hands to check I can only assume based on previous knowledge and information shared on the forums.
As strange as it may sound, this is why I can't wait to get my V4 (which is getting closer and closer each day! It's in my country now at least).
While the EZ-Robot tutorial videos are amazing (it's where I learned all of what I know to be honest) there are times when users need a bit of personalised guidance or some step by step text based guides. This is where I will jump in when my V4 turns up.
The controls, GUIs etc. for the V4 have been there for a while and, me being me, I got nosey. While I couldn't do anything I already have a good idea of where to go and what to do... provided it's been built the correct way (and I'm confident it has been).
@Lumpy, I'm playing blind here but let's put me to the test a little... You said it's connected in client mode but you can't find it on the network? I am expecting that in the config for the WiFi on the V4 there are options for DHPC or fixed IP addresses etc. Did you (if they exist) fill anything out there? Is it on the correct IP range? (i.e. 192.168.1.xxx and 192.168.0.xxx will not communicate with each other and if it's on the wrong one it wont be found).
If you are confident that it's connected and been assigned a proper IP there is an App I like to use called Fing Box. Download it and scan the network to find the V4. If Fing doesn't find it then it's not actually connected to the network and you'll want to check the network settings.
If someone wants to send me screenshots of the config pages for the WiFi on the V4 (anyone with a V4, someone from EZ-Robots, it doesn't really matter who) I may be able to make better assumptions and better guidance until my V4 shows up.
Hi Rich, In client mode it asks for SS ID and network password.
Enter those two and hit connect. It the reboots and announces it has connected to network.
I don't see anywhere for advanced settings as of yet.
I installed Find and will give it a try when I get home tonight.
Lumpy, I've not seen the screen where you get the SSID and password prompt. What did you do to get that screen ?
Robot doc,
You need to connect directly to the Ezb wifi.
Once connected open your Web browser and enter 192.168.1.1 and it will go to the Ezb Web server screen. That is where you can configure the Ezb.
