TCP Client icon TCP Client — Telnet-like ASCII TCP client for ARC: connect to IP:port, send ASCII, view raw or HEX server responses with local echo Try it →
Resolved Resolved by Nink!
Which way should I go for Spot Micro?
Which Way Should I Go For Spot Micro?
I have completed the mechanical assembly of Spot Micro.    There are several versions for the controlling mechanisms used by various people.  Here is a very cute one that is done with an Arduino Mega as the controller with embedded code in the Arduino.   However, I have other options too such as either using a EZB V4 or a RPI with a servo Module and some reverse kinematics software.
If I decide to use the EZB V4, this is not that different than the "Six" robot in complexity (maybe).   I have the parts and I am trying to determine which way to go.   The kicker will be designing each step of movement with frames using ARC.  I have not tried anything this complex control-wise.
USB
Digital 21
Twitter
#25
It was a nice hot day in Toronto yesterday so I had a few beers on the deck.
woke up this morning and I found this on my work bench. A couple of JD’s had been sacrificed to the robot gods.
I guess I can clean it up and throw some code down.
Let’s call it JDog.
#26
Hahaha oh my - those must have been good beers. I spit out my milk and laughed at that thing. Bet it walks great and is very stable. Just kinda caught me off guard
