Sound Servo (EZB) icon Sound Servo (EZB) — Map EZ-B audio volume to servos; multi-servo mirroring, scalar range control, invert/min-max, waveform feedback to sync mouth motion. Try it →
Depends on your printer's extruder type... Forget using an MK10, or 11 or even a bowden extruder... If you want to print flexible material you should buy a flexion extruder for your printer....
I can print with the Ninjaflex but I can't print what you need for 2 reasons. The print is too big for my printer bed (Makerbot Rep 2) and It will take a dual head printer, which mine isn't. The way they have the print, you will need to print supports with a solid filament and the hand with the Ninjaflex. Nicely designed hand though but the price of those linear actuators - wow!
@richard r, thanks for the info, although I don't think anyone makes extruded for my solidoodle4 they are out of business.
@Bhouston, thanks one of these years I will buy a bigger and better printer. I don't want to spend the money just to test this hand. I'm going to see if a local 3D print service in my area can print the left hand palm.
Cheers,
Probably your best bet, it's a difficult print.
