Personality Generator icon Personality Generator — Background randomizer that executes timed scripts to add lifelike actions (movement, servos, camera/control) and unique personality to your robot Try it →
Who can help
initalvexgrippertest.EZB I need A lil help with some programming. It's been a year or so since I've written anything. I'm trying to set up a simple test with 2 grippers. I can get them to open/close individually, but can not them to open/close same time. I'm sure I'm forgetting a sequence  or command. Did try to use the help but no luck. Been stuck on this for over a week now.Any help or idea would be great. I'm provingso e code that I've tried to do.,..
Sorry, first number is the ezb number. I have 4 of them in my robot. Second is the port number and third is the servo speed I want to set.
Autoposition is the way to go. Great feature.
hi dave thanks for the info.so thats connection number 2.
No its same erro a 404.
(anyone recognize the metal material the ripper are attached to?) vexgrippertesting.EZB
So I've now added a limit switch and an IR sensor to each gripper. The grippers are spring loaded, so the switch is to help stop the servo to prevent overheating. The ir sensor is simply gonna be used to indicate something is there to grip and to make it close. Still working on how to..
