Hello DJ Sures, Is it possible to connect a Wishield 2.0 to the EZ B??? And if yes, how would I go about setting it up so I can control it from the web/smartphone???
Thank You
Frequency Detector
— Detect audio frequencies via PC microphone (FFT), output a variable and drive servos within configurable min/max ranges with waveform feedback.
Thank You
I'm not sure, but you can just replace the bluetooth module by a WiFi serial module and connect the ez-b to your pc via wifi and make a web-server in ARC to remotely control your ez-b
Hey Lyron, thanks for the suggestion but how would i go about doing that??? Sorry for the noob questions.
Thanks
Chrstnslts, here are some links to get you started...
HTTP Server Tutorial Wi-Fi Add-on for EZ-B Instructions on how to connect/configure the device can be found on both of those pages.
Thanks TXTCLA55!
