Tic Tac Toe icon Tic Tac Toe — Play Tic Tac Toe with your ARC robot: configurable turn, win and draw scripts, cheat commands and optional speech-recognition control. Try it →
Denmark
Wifi Client Mode Wont Connect
Hi
I just recieved my EZ-B v4 yesterday and finally got around to play a bit with it today. Everything seems to work fine, except that i cant get it to connect in client mode to my wifi.
Heres what ive tried: Connected to the EZ-B Then visited 192.168.1.1, and went to "Wifi client mode", Entered the SSID of my network and the WPA2 passphrase. I then click connect, i get a green light and the "pling" turn on sound, and then i get somthing like "I am unable to connect to your network" and a red light.
I have tripple checked the SSID and Password. So right now im kinda out of ideas...
Btw. its a ZyXel P-2812HNU-F1 running 802.11 b/g/n mixed with WPA2 (TKIP and AES)
Do you have an 802.11g, n, or ac router? If ac and you only have 5.2ghz enabled you will need to enable 2.4ghz g and n mode.
Denmark
I just updated with the settings. Its not AC, its running 802.11 b/g/n mixed
I hate to even suggest it, but verify the ssid and password are correct. Both are case sensitive.
ie, my ssid is FBIsurveillanceVan, fbisurveillancevan would fail to connect even with the right password.
Denmark
Ive checked that several times, my ssid is TheHoneyPot and the password is all caps, and also tried copying the password directly from my laptops wifi settings. just to be sure
just for giggles, try to set your ap to use AES instead of both AES and TKIP.
Denmark
It was worth a shot, but no luck:(
Sounds like time to rule out a problem with the EZ-B itself. Do you have a friend with a network you can connect to, or do you have a phone with mobile hotspot ability? If it fails on multiple networks we can stop looking for network config issues.
Denmark
Okay this i so weird... Suddenly when i booted again and about to reset to try the mobil hotspot, but before i got to press reset, it connected successfully.. i then rebooted again to check if it kept working, but then i got the error again.
I have now tried the mobile hotspot, and it works fine, so its not the ez-b it would seem.. But the weird thing i that i actually got a connection 1 time
