BV4615 RC-5 IR Decoder icon BV4615 RC-5 IR Decoder — Adds IR sensor support and button mapping for USB joysticks in ARC, enabling remote control functions; third-party hardware supported. Try it →
Are you asking if you can connect your PC to Ethernet (internet) and WiFi (ezb)?
Yes, you can - long as your Ethernet network is not 192.168.1.0/24... Meaning the network is not the same as what the EZB network is. If your Ethernet network is 192.168.2.0 or 192.168.0.0 or 192.168.8.0 or 10.0.0.0 or 10.0.1.0 or etc etc etc... then you're okay
If your Ethernet network is 192.168.1.0, you are not okay.
It is easy to change your Ethernet network. Simply log into your router and type in a new network. It's as simple as typing in 10.0.0.0, is what I like to use.
Otherwise, you can have your EZB connect to your network and then you never need to connect directly to the EZB. I would recommend clicking on the LEARN section of the website and browsing to the WiFi Modes tutorial
Just a note: I am trying to get details, but there is a Windows 7 and above group policy setting that can disable WiFi when an Ethernet is connected. If you are using a work computer, you might need to have your IT department disable this function in order to connect to your Ethernet network and EZ-B wireless network at the same time (or easier, as DJ mentioned, you can put your EZ-B in client mode on your network and have the computer reach it from its Ethernet connection).
I am trying to get details on this setting since it impacts my work computer. My Windows XP machine, they did it through an application I could disable, but in Windows 7 it is a policy setting, and I may not be able to control it (I have admin rights, but some functions are still not allowed).
How do i disable that function?
@DJSures. Wait so I can connect my EZ to my router module instead? How do we do that? And can you please post the link on here? I'm not accustomed on the new layout of the website. Sorry _
I don't know yet. As I said earlier, I am researching it. It should be off by default on a consumer computer. It appears to be a group policy available on corporate computers.
Go to the learn section and take the WiFi lessons. https://synthiam.com/Tutorials/
Technopro also did some nice video tutorials that explain the different modes: https://synthiam.com/Community/Questions/5901
Thnx but I still have a to connect to my EZ-B which is my real problem.
Looks like I was wrong about there being a group policy to disable WiFi when Ethernet is connected. I found that there is an application on my work computer that does that (Wireless Autoswitch XPV by Sase Shame, Inc). So you should be able to connect to the EZ-B and your Ethernet wired network at the same time as long as your wired network is not in the 192.168.1.0/24 subnet.
However, if you have a wireless router, still probably better to get the EZ-B into client mode on your network rather than trying to run two networks on one machine. Less problems overall.
Follow the tutorials or videos I linked, let us know if you get stuck.
Hello @deuel18,
Were you able to connect to the ez-b via client mode?
