Sphero Movement Panel icon Sphero Movement Panel — Control Sphero via Bluetooth in ARC. Detects two COM ports (one connects); requires deleting and re-pairing after disconnects or reboots. Try it →
As you can see, there are several efforts and resulting posts about the WiFi board suggested for use with the EZ-B. At this point in time the best choice for wireless connections over 35 feet would be class 1 bluetooth devices. One installed in the EZ-B and the other in the USB port of the PC, that connection will provide up to 330 feet.
Several members are in the middle of identifying and ordering other WiFi boards so this is still an ongoing process.
