can anyone help me get ez hooked up to wifi? i got Uart-Wif but can not get it to work. I can't put a computer on robot to much weight.
is there another wifi that will work with ez? mad
Advanced Speech Recognition
— Azure Cognitive Speech recognition for ARC with custom API credentials, scripting, language control, and text output for detected phrases
can't wait,glad to see someone still trying
I'm wondering if this will work for the virtual com port: VSPE?
I'll give it a try tomorrow.
I'm also wondering if I shouldn't get a second TLG10UA03 (for the host computer) and run in transparent mode, on an adhoc network, and then bridge maybe? Just throwing out ideas here. Documentation on this thing is rather lacking.
Anyone know where (in English), to get FW updates?
Ok, auto-join solved. Check "Auto Mode Enable" in the www interface, (once they're talking) TCP for a protocol, and SERVER for the mode. You can now disconnect the module from the UART module and power it separately and access it via it's IP. Works a treat.
So I just need a virtual serial port to interface with ARC now and it should all work. I suspect the module's transparency mode options may be the key.
And I can see the UART-USB module being a very useful tool for other projects beyond robotics.
Oh, crap. Make sure you save,.
I'm thinking that this, although pricey, will work for the virtual comport: WiSnap
what are you using now? I have TLG10UA03 from elechouse
Same. But I need a virtual serial port. I think this will do the trick for the host computer end of things.
