Brushless Motor Movement Panel icon Brushless Motor Movement Panel — Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement. Try it →
Hi Pittom,
The range on the Uart-Wifi module won't get you too far AP to Module...maybe one house over if you are lucky. XBee or Synapse have much better range for serial communications from what I have seen. If you have wifi at both locations this is doable with IP port forwarding.
I am also having a bit of trouble getting my Wifi UART to work with ARC...there are a few in the forums that have. I have not spent too much time on it lately but will be picking it back up soon.
v/r
Kevin
hi kevin,
i can't get my Uart-Wifi module to work yet with EZ, but that is what i was thing IP port forwarding
did anyone get the Uart-Wifi module to work yet confused mad
