Feetech Serial Bus Servo icon Feetech Serial Bus Servo — Control Feetech SC serial bus smart servos via EZB UART or PC COM port with ARC virtual ports, speed, position, release, and acceleration. Try it →
I have the base for one. But i do not have the upper body with webcam. So i technically could easily add support for the motion, but not camera because i have no way of testing.
Do you have one? I'll add support if someone can test for me
Hi Dj got one sat on a shelf , was looking at combining the ez robot and spykee .
I'll get one and test for you should be fun
Spykee has a great base but it is a pain if you get a bad firmware flash.
Samantha
United Arab Emr
Hi, Any update on this subject I do have robosapien and spykee already . Each one has many disadvantages that need enhancement to return the value to the money spent. The ez-robot kit should arrive any time now and I look forward to hack both of them.
Regards, Hhammoud
United Arab Emr
DJ, I do hope that you can spare some time to work on the wifi spykee . It is quite good base that has potentials if we combine it with ARC. Thx in advance HH
