Wifi To Bluetooth
I have a EZ B v3 with a Bluetooth module. I downloaded the newest software and it looks like it uses wifi to connect to the board. Is there way to switch wifi connection to Bluetooth ? Or should I download the older version of the software ? Thanks! Shak
you can still connect to bluetooth V3. In the connection dialog where it shows an IP address, click on it, and the comm ports will be in the dropdown list.
The Ezb v3 is Bluetooth only not wifi
When I click the drop down button it only shows the ip address not the com ports.
Is your EZ-B paired to the computer? You first need to pair it for the comm ports to be defined.
