Talk Servo V2 icon Talk Servo V2 — Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop. Try it →
Resolved Resolved by Nomad 6R!
Wifi Connection Problems
No matter what I do I can not connect the EZ-robot EZ-B v4 to wifi. I refuse to go Pro Sub. when I am only using one laptop.  Would I have to redownload ARC again? Chris
Hello @indywriter
Have you checked out this troubleshooting page? Common issues are:
  • Anti-virus blocking - disable anti-virus software (Windows defender is fine - don't mess with it, but Norton is known to cause issues)
  • Trying to connect with client mode when direct AP mode is sufficient
  • Router IP address conflict (same IP address as router) when ethernet is attached - try removing
If you have a USB wifi dongle you could try connecting on WiFi 2
hi indywriter/jeremie
also delete your browser history and reboot pc .if you had many try's .
I have had issues with Windows firewall blocking access.
Thank you all for your help. My Wi-Fi problem has been resolved.
