Vertical Servo icon Vertical Servo — Drag vertically to control a servo within set min/max limits; center, release, invert, and mirror to other servos. For 3-wire GVS servos. Try it →
Wii Controller Not Working Consistently on Windows 10
Wii Controller Not Working Consistently On Windows 10
Hello,  I'm having a lot of difficulty getting  the Wii controller to work consistently on Windows 10. I've searched everywhere for answers but must be missing something. I can (inconsistently) Pair it and ARC will see it in the control but once I reboot the laptop the control no longer sees the remote in the pulldown, it is still paired but the 4 blue lights are blinking if I press any button.  I then have to remove the controller  in bluetooth and re add it. This doesn't always take and it doesn't guarantee that I'll see it in ARC.  I though it might be the controller, I tried another and also have the same issue with the Wii Motion Plus. I've tried the Julian Lohr driver but could not get that working in fact now I cannot add the controller at all in bluetooth.
Any Ideas? Or is there a better controller out there with the same functionality (accelerometer, buttons, etc)?
TIA - Steve
Roli Rover by EZ-Robot
Roli Rover with Synthiam ARCx: drive with live video, control arms, follow faces, patrol, and program with Blockly or Python
Wii Remote by Nintendo
Control servos, movement panels and scripts via Wii Remote or mobile accelerometer; D-pad, buttons and Home-enabled accelerometer tracking.
#1   — Edited
The manual for the wiimote skill has information about that:
here’s a direct link to the wiimote manual: https://synthiam.com/Docs/Skills/Misc/Wii-Remote?id=16080
we do use vr controllers from the vive on an internal project - but the code isn’t available at this time. It does require a lot of hardware configuration because it needs beacon stations setup around the room. There aren’t a lot of options for that style of controller without a lot of effort.
Thanks DJ for the fast response - i must have read right passed that! Much appreciated.
If it helps - we all feel your pain with the WiiMotes. They're pretty great controllers but the PC bluetooth driver implementation leaves much to be desired:)
