Brushless Motor Movement Panel icon Brushless Motor Movement Panel — Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement. Try it →
i follow the tutorial here from dj and did excacly same. it not chowing in devices. the blinking off the blue leds dont last long. no errors
thank you rich
#18
Hold the number 1 and 2 buttons and the lights will start blinking.
Go to your pc and go to Bluetooth. Click add device.
Keep holding the buttons.
When the wii remote comes up in add devices, click it and click the option of pairing that doesn't have a code required.
Keep holding the buttons until the drivers are installed.
Note: if the lights stop blinking on the wii remote, repress the 1 and 2 buttons and hold.
Once paired, go to ARC and add the wii remote control. If the wii remote turned off, turn it back on(press a button on it).
Press the home button on the wii remote and the red dot on the wii remote control in ARC should go green and start moving with your movements.
sorry for late respons.i try it very long,but i dont see it appear how can i see iff the remote is on?
#20
You can tell it's on by the 4 flashing LEDs on the lower portion of the WiiMote. If the LEDs don't light up your batteries are too low.
i ordere a special wii batt from 2600 mah.hope that helps
#22
I guess I should specify that the LEDs only flash when you press buttons 1&2 together for pairing, they don't flash all the time.
hi jeremie
i have win7 and bt anycom 2.0
thank you
i recieved the batt pack for nintendo.3600 MaH hope this helps.
