NMS Navigation Data Grabber icon NMS Navigation Data Grabber — Query NMS lidar scan data by angle, with control commands for range, arc extremes, and obstacle checks from the latest scan. Try it →
Wild Thumper Street / Indoor Tire Conversion 4wd Or 6wd
Wild Thumper Street / Indoor Tire Conversion 4Wd Or 6Wd
Hey guys sharing this for anyone who wants or has a wild thumper that you can make it a little more indoor friendly and these tires would have better control on smoother non-off-road applications. This is a streettire wheel from dagu and comes with a brass hub.
The swap is very straightforward. There is a hub on the end of each geared motor. There is a Allen screw holding the hubs on in the center , remove all of them.
Once you have removed your off-road wheels and tires you will have threaded posts to mount the new brass hubs.
The smooth indoor / street tires and wheels have their own brass hub adapter and include a matching Allen wrench.
Here's a screenshot of the product you need from dagu to change the wheels.
