Soundboard (PC) icon Soundboard (PC) — Play and manage MP3/WAV sound effects from a PC soundboard, load tracks, trigger or script playback (one file at a time), export and automate. Try it →
Will The 2.5 Amp Motor Controller Work With This Motor?
https://www.robotshop.com/ca/lynxmotion-ghm-13-gear-head-motor.html
Lynxmotion 12VDC 152RPM 231.05oz-in GHM-13 Spur Gear Head Motor
12vdc 141rpm, Gear Head Motor / Part no. GHM-13 Torque = 231.5 oz. in. Weight = 7.15 oz. Reduction = 30 :1 Length = 59.2mm (motor and gear) Length = 22.6mm (shaft only) Diameter = 36.8mm (motor and gear) Diameter = 6mm (shaft) (0.157") Current = 145mA (at 12v no load) Current = 3.8A (at 12v locked shaft)
It might but it depends on the load , at full load stalled is 3.8 , so on average it probably draws 2amps or more. It may run it fine if you don't overload it.
