HTTP Server icon HTTP Server — Remote web control of ARC desktop: live screen interaction, movement control, camera list, EZ-Script/ControlCommand console with remote execution. Try it →
Temperature sensor: Looks like its an i2C sensor? So you have t figure out how to read the data from it, but yes, it can work with the ez-b.
Relay: Maybe its UART? I can't really tell, but if it is, then yes you can use it with the ez-b, just do a little scripting.
Though, for both of these there are way easier alternatives. Try to get sensors that work over adc, as it is a few lines of code to make it get the value and print it. As for the relay, try these with a diode on the signal wire: 5V relay
To add to @Techno was saying.
I looked into it and, yep, the temp sensor looks 100% compatible. It runs off 3.3V and sends an analog signal out. You just need to hook it up to 3.3V, GND, and an analog pin (A0-A7) on the ez-bv4.
As for the relay, it looks like the v1.2 will work since it can run at 3.3V voltage but the v1.1 may not.
