Since i got hte eb form a diff. website, it came with no power supply...
Sures states to use a 5aa battery holder, will this 8aa work?
until i get 7.2 6800mah battery pack
thanks guys
carlos
Ez Line Chart
— 4-series historical line chart to log and compare robot sensor values over time with customizable titles, colors, time axis and EZ-Script control
thanks guys
carlos
The size looks right but you should make sure that there's a convenient way to connect the leads from the battery pack. The power adapter that comes with the kit is cool because it has screw-in terminals for the leads. Just my two cents but you're going to want access to the battery leads for a variety of purposes (e.g. DIY voltage monitor, power supply to an H-Bridge, etc.) so I would avoid merely soldering the battery leads to the plug. If there's no obvious way to do this, pick up a $2 "European Terminal Strip" while at Radio Shack and cut off 2 segments to give you convenient screw terminals to the wires. Let me know if you need more info.
thanks again Choy...i really appreciate your time.
im so dumb..i didnt know the ezb comes with a power supply and adapter.
I knew Sures sent case and adapter with the ezb, but since i got my ezb from the Shed....and they didnt mention anything about it, i figures i needed to get on that...
anywho, it came with he battery case and adapter and im already using it...sooo freaking easy. i love it.
THANKS!
