SMTP Client icon SMTP Client — Send SMTP email (text or camera images) from ARC robots via ControlCommand; configure SMTP/auth and sender; saves credentials in project. Try it →
Will A Single Autoposition
Will a single  autoposition control ever be able to access multiple EZb's/IoTiny?
For example I have 2 IoTiny's ,one in each arm of my inmoov operating the fingers, wrist and elbow.  Right now I have to use 2 autopositon controls and then make a script to try and tie the action together. It's a little counterproductive.
The reason 3DGuy uses Two iotiny is he put one in each arm of his Inmoov robot this is to make each arm a wireless connection and that is to avoid a large number of wires in the arms going to the controller.  I have done the same in my Inmoov robot Bruce-e.   using a ssc-32 in the inmoov would not address this issue, of two many long wire runs and of the AutoPosition control only working with one Iotiny controller at a time.
