Will the 3 wire Grove - Ultrasonic Distance Sensor work on the Arduino mega
Will The 3 Wire Grove - Ultrasonic Distance Sensor Work On The Arduino Mega
Hello,
I am trying to free up many digital ports on my arduino mega and seen these Grove - Ultrasonic Distance Sensor.  Will they work on my arduino mega?
Thank you in advance.
Edited:  link to Grove - Ultrasonic Distance Sensor https://www.seeedstudio.com/Grove-Ultrasonic-Distance-Sensor.html?gclid=EAIaIQobChMI5fKn6rOn8wIVPXNvBB1GFgkpEAQYASABEgIsTvD_BwE
USB
Digital 21
Hi EzAn.
I have not used or tried using the Waterproof Ultrasonic Distance Sensors.  I only use the 3 Wire Grove - Ultrasonic Distance Sensor.
BTY, the 3 Wire Grove - Ultrasonic Distance Sensor does not fix any of the standard 4 wire HC-SR0 Mounting brackets,boards.  I have not been able to find any that fit the 3 Wire Grove - Ultrasonic Distance Sensor.  I have to hot glue them to the Mounting brackets,boards.
I haven’t really played with them yet I’ve been doing other things that need done first.
Take care and talk to you later. cheers
