Python Native icon Python Native — Run real CPython in ARC with full package support, camera access, ARC APIs, and bidirectional robot control. Try it →
Resolved Resolved by Athena!
Windows 11 TTS With ARC
Can ARC utilize the Windows 11 Text-To-Speech (TTS) engine in conjunction with ChatGPT, instead of the other TTS skills provided within ARC? This would allow users who are implementing projects on Windows 11 Single Board Computers (SBCs) to take advantage of the onboard TTS capabilities built into the Windows operating system.
Lattepanda by DF Robot
LattePanda with Synthiam ARCx runs headless, loads EZB firmware on the built-in Arduino, and controls robots from any browser
Servos 12
UART 1
ADC 5
Digital 12
Offline Windows speech recognition with open dictionary, confidence filtering, and scriptable phrase actions for ARC robots
ChatGPT chatbot for robots with memory, image description, personality scripting, and voice conversation via OpenAI API
Yes, ARC can leverage the builtin Windows 11 TTS engine for text-to-speech output. Essentially, when you use commands like Audio.say() or Audio.sayEZB() in your scripts, ARC is calling on the underlying Windows speech synthesis system. This means if you’re running ARC on a LattePanda or another Windows 11-based SBC, it will use the onboard TTS capabilities provided by Windows-even in projects that incorporate the ChatGPT robot skill.
Here are a few points to consider:
When using the OpenAI ChatGPT skill, by default the returned response can be made to speak out using the Audio.say() command. Since this command calls the Windows TTS engine, you will effectively be using Windows 11 TTS with your ChatGPT responses.
If you need to customize the speech (for example, adjusting voice, rate, volume, or adding effects), you can configure these options within the Speech Synthesis Settings skill. Even though this skill is designed to modify the built-in Windows speech synthesis, it lets you take advantage of Windows TTS while still providing extra control over how the speech sounds.
For users running projects on a LattePanda with EZB Firmware, you’re already set up to use the native Windows TTS. All you need is to ensure that the scripts or control commands which invoke TTS (like Audio.say()) are used in your ChatGPT response handler.
Overall, by combining these approaches, your ARC project can utilize the Windows 11 TTS engine natively in conjunction with ChatGPT, letting you enjoy the benefits of the onboard TTS without necessarily needing an additional TTS skill.
Does this answer your question, or would you like further details on configuring your project to make sure your ChatGPT responses are vocalized via Windows 11 TTS?
Yes thank you for confirming what I thought was the case Athena!
You're welcome, smiller29! I'm glad I could help clarify that for you. Do you have any other questions or need assistance with any other ARC configurations or robot skills?
Hi smiller29,
Yes, ARC can work with the builtin Windows Speech Recognition capabilities-which on Windows 11 provides Speech-to-Text functionality-through our Speech Recognition skill. In other words, when ARC is running on your LattePanda (or any Windows PC SBC) with Windows 11, it will leverage the local speech recognition engine provided by Windows rather than a cloud-based service.
Some tips and details:
The Speech Recognition skill in ARC is designed to use the Microsoft Speech API (SAPI), which works on Windows 10 and Windows 11. It takes full advantage of the local STT engine available on your system.
You can configure microphone settings (via the Setup Microphone button in the skill) to optimize sensitivity and reduce background noise-a key factor when using local STT.
The skill also allows you to adjust the minimum confidence threshold for detected phrases, helping tailor performance to suit your environment.
While ARC’s current implementation is based on Windows’ built-in speech recognition, we are always looking at ways to improve speech functionality. Feedback from users like you drives ongoing development.
For more details on configuring the Speech Recognition skill, please check out our support document: Speech Recognition Skill by Synthiam
Do you have any additional questions about setup or configuration? I'm here to help!
Can you use this skill with ChatGPT?
Yes, you can use the Speech Recognition skill with ChatGPT in your ARC project.
Here's how it works:
The Speech Recognition skill leverages the Windows built-in STT (via the Microsoft Speech API) on your LattePanda running Windows 11.
When using the Speech Recognition skill, the text captured by the local STT engine can be transmitted to the OpenAI ChatGPT skill.
You can configure your Speech Recognition skill to trigger a ControlCommand that sends the recognized text to ChatGPT-typically using ARC’s ControlCommand() function.
For example, if you have your Speech Recognition skill set up to capture your phrases, you could use a line of code similar to:
controlCommand(OpenAI ChatGPT, Send, getVar($SpeechText));
In this sample, the variable $SpeechText would hold the text recognized by Windows' STT engine, and the ChatGPT skill would then process that input.
For more details on each skill, check out these resources:
OpenAI ChatGPT Skill
Do you have any additional questions about integrating these skills or any configuration specifics you’d like to discuss?
Athena, I was trying to use the speech recognition skill today with the ChatGPT skill and I could not make it work by adding the following to the All Recognized script location
controlCommand("OpenAI ChatGPT", "Send", getVar("$SpeechPhrase"));
The issue is that it only works if the phase is in the phase list.   Where should the command script go within the skill when you want to send the speech that is not in the list of phrases? I am not sure this can even be done based on what I seen tonight.   How does the skill know when you are done talking?
It would be nice if the enable phase could be used as a wake phrase for whats in the list and what not.    So, let's say the enable phase was "Hey Robot" it would enable the speech recognition for what's in the list and what you may want to pass to the ChatGPT skill for the speech that follows the enable phase. when the above command  gets sent then we pause things until the enable phase is detected again.
Below is some additional insight and a potential workaround for how to get freeform speech (speech that isn’t part of your preset phrase list) to be sent to ChatGPT.
Understanding the Default Behavior:
The Speech Recognition skill is designed so that when a phrase matches one from the phrase list, the associated command script is run.
This is why your line
  controlCommand(OpenAI ChatGPT, Send, getVar($SpeechPhrase));
only seems to work when the spoken phrase is already in the phrase list. When it isn’t, no command is triggered by default.
Capturing Free-Form Speech:
To forward speech that isn’t on your list (for example, after a wake phrase), you must change how the Speech Recognition skill "handles" freeform input. There isn’t an out-of-the-box field labeled "All Unmatched" for freeform speech. Here are two approaches you might consider:
1. Using an "Enable" (Wake) Phrase With a Toggle Variable
   In your phrase list, include a wake command like "Hey Robot" that, when recognized, sets a global variable (for example, setVar($SpeechEnabled, true)).
   In the same script (or a subsequent one) you can clear the recognized phrase variable (i.e. $SpeechPhrase) so that the skill is now "open" to accept freeform input.
   Then, in the "All Recognized" script, use logic to check if $SpeechEnabled is true. If it is, then regardless of whether the recognized speech is on the list, pass the recognized phrase to ChatGPT. For example:
    if(getVar($SpeechEnabled)) {      controlCommand(OpenAI ChatGPT, Send, getVar($SpeechPhrase));      // Optionally, clear $SpeechEnabled so you only forward one entry until the wake phrase is redetected.      setVar($SpeechEnabled, false);     }
  This approach gives you a "wake-and-listen" mode: say "Hey Robot" to enable freeform speech capture, then speak your free speech that gets forwarded to ChatGPT, and then the system turns off freeform capture until you say "Hey Robot" again.
2. Customizing the Script Trigger
   By default, the Speech Recognition skill only fires the command script when a phrase is matched in the list. To capture freeform input (even when the phrase isn’t in your list), you’ll need to modify or extend the default script behavior.
   If the skill supports a "Low Confidence" or "No-Match" script field (some versions have an extra field for unmatched phrases), you could place your command there as well-so that any speech that doesn't match an exact phrase still gets sent off.
   If such an option isn’t available, you might need to lower the recognition confidence threshold to capture more input and then (in your "All Recognized" script) filter out any phrases that are still not your wake phrase or intended commands.
How Does ARC Know When You're Done Talking?
The speech engine itself (via SAPI on Windows) is responsible for determining when a phrase is complete based on pauses in the sound.
Often there’s a short delay after you stop speaking (or the engine detects silence), and then the phrase is finalized.
Unfortunately, there isn’t a built-in "you’re done talking" flag available in the basic configuration. That’s why many users employ a wake-enable mechanism or have a "Send" button to manually trigger sending the freeform text.
Summary
Currently, out of the box, freeform speech (not on the phrase list) isn’t automatically passed to the ChatGPT skill because the Speech Recognition skill only triggers command scripts when a matching phrase is detected.
To work around this, you can use a designated wake phrase (such as "Hey Robot") that sets a flag which then causes your "All Recognized" script to forward any subsequent recognized text-even if it’s not on the list-to ChatGPT.
This requires some custom scripting logic:
  - In the wake phrase command script, set a global variable (e.g. $SpeechEnabled=true).
  - In your "All Recognized" script, check for that variable. If it’s true, forward getVar($SpeechPhrase) to ChatGPT, then you can optionally reset the flag.
By following this approach you end up with a mode where, after saying your wake phrase, anything you say is forwarded to ChatGPT until the system resets back (or until an "end" phrase is detected).
I hope this clarifies the behavior and provides you with a potential solution! Let me know if you’d like further details or assistance setting up the wake phrase mechanism and custom scripting.
