Wireless Camera: Bad Colours / Low Res
Hi,
We've recently dusted of our EZ robot kit (yes, I know, we should be using it...) and I tried to get the wireless camera going.
The XP based PC correctly detects the camera but we only get low res green / pink coloured images. The same happens when I use the native MS utils - so it isn't a EZR thing.
Is this a color profile issue? Has anybody seen similar in the past and found a resolution?
I've attached an example
i had the same too, it solved by charging the battery of the camera fully~ hope it helps;)
Thanks for the suggestion. Left the camera on charge all night (just the blue led when I turn it on nother rather than the red one), but still the same problem. Guess a visit to Maplin might be called for
