Live Stream Broadcast icon Live Stream Broadcast — Broadcast live audio and video from ARC camera to the web via HLS; cross-browser streaming. Requires router configuration for external access. Try it →
India
Wireless Camera Question
When I connected the wireless camera to EZ-B, the fuse between the heat sinks burnt out... I guess it might be due to the some wrong connections... What should be the connections for the wireless camera.. As I imported the kit, the battery from the camera was removed... How should I supply the power from EZ-B and make it work?
Red to where the battery + went. Black to where the battery - went.
Can I connect a 9v battery to the camera?
Good god no. 5v from a digital port is pretty much the limit.
Most certainly not it can be powered by the EZ-B board using a servo lead that you cut and solder to where the battery went
You just beat me to the draw Rich
Can you be a li'l bit clear please.. I didnt get you...
Heyy, Got it.. I connected the camera to the digital port and it works perfectly fine...
Hi Pravnav
Glad you got there the link I've added should also help you
Follow this thread Here
