Sound Servo (PC Mic) icon Sound Servo (PC Mic) — Maps PC microphone volume to servo positions - control multiple servos (e.g., robotic mouth) with scalar, min/max and invert options. Try it →
Wireless Microphone
Wireless Microphone
I have been trying to use a wireless microphone for speech recognition but cant seem to get it to work. If I go into the microphone settings via the control panel on my computer, I can see the level indicator moving when I speak into the mic and I set it as default. Also tried changing levels with no luck. Has anyone else tried one of these mics? I was hoping to have a mic that was not too noticeable but if I cant get it working I might have to get a head set.
Thank you for this. I will have to pickup one of these.
Glad you got your mic working. Also thanks for the suggestions. Food for thought. I have kept Toymakers suggestion in mind since I first read it last year. It seems like a quality unit. However I'm looking for something I can place out in the room with the CPU mounted in the robot. I also had thought of the ceiling mounted type after seeing them in a conference room at work. However that still leaves me how to get the signal to the robot mounted computer. I'm intrigued with the possibilities of a good smart phone used as a stand alone Wifi microphone set on it's speakerphone setting. I haven't looked very closely at this so I don't know if it can be done but seems possible. If your ever looking for a wired desktop microphone that does a real great job it's the Blue Snowball. It's a bit pricey but it's configurable and does a better job with voice recognition then others I've tried. It's problem like all others is if there is a lot of noise in the room it has trouble. However if set up properly it still out preforms other expensive mics I've tried.
I just wanted to add that I'm still looking for something like a DSR (distant speech recognition) microphone. The only one I have come across is the Voice Tracker l and the Voice tracker ll microphones that can apparently do the job and works well with conference calling. But at $276 and $360 respectively, that's a bit more than I would like to pay for something with no reviews with use with speech recognition.
I did recently buy a new mic called a CrispMic, which is USB connected and designed for speech rec and VoIP communication, but I'm not that happy with it just yet. It can pick up my voice up to about 2 meters away, but recognition is patchy at best (but this could also be due to me using a fairly new laptop so A LOT more Windows speech rec training is needed).
I'm looking for something I can plug in to an Acer W3 and have the mic installed in K-9. I'm still using my iPhone for Pandorabot control recognition via a VCN app which still works great (gotta love that iPhone speech rec), but it's still a case of holding a mic in front of your mouth and pressing a "Send" button to pass my spoken phrase to ARC. Having a mic on-board where anyone can speak to K-9 without holding a phone or holding/wearing a microphone is still a dream for me at the mo, and I'm always on the look out for something I could use.
Bangladesh
Google+
Quote:
If you set it as default while ARC is open, ARC will need to be closed and reopened to initialize the device.
I also agree with DJ. If you still have any problem then contact with xiontech's specialist. www.xiontech.net/
#15
Resurrecting this thread because of some good fortune I have had with Windows 10. I have struggled to get voice recognition working on my Acer W3. Plug in mic's just didn't work, and Bluetooth headsets would connect and then disconnect (I have had trouble with Bluetooth on all Windows 8.1 computers. Worked better in Windows 7).
I upgraded yesterday to Windows 10 (see note below about upgrading the W3) and now two of my Bluetooth headsets work perfectly. I can set the Mic as the default input and still have the ACER speakers be the default output if I want (although I will be sending most sound out through the EZ-B anyway). It works with A Motorola H710 and a Plantronics Legend-PLT, which can simultaneously connect to my phone and flawlessly switch between devices when I get a call. It does not work with my Plantronics M165. When I turn off the headset, the internal becomes the default, and when I turn it back on, it automagically becomes default again. However, I do need to have the headset connected before I start ARC or it doesn't hear it. I can live with that...
Note on Acer W3 upgrade to Windows 10: If you check compatibility from the Windows 10 reservation tool, it will tell you there is not a compatible driver for the video, but I did some research and the video doesn't need a driver. Youc an download the media creation tool from here: https://www.microsoft.com/en-us/software-download/windows10 and when you run it, select "upgrade this machine" and it will upgrade just fine. (you might need the driver if you connect an external monitor with the Micro HDMI cable. I haven't tried and have no need to). I am going to post this as a separate thread as well since a lot of us use the W3 for our robots.
