Personality Generator icon Personality Generator — Background randomizer that executes timed scripts to add lifelike actions (movement, servos, camera/control) and unique personality to your robot Try it →
Wireless Connection To Arduino?
I’m building Spot Micro Next. The base design uses a Arduino Mega.  I’d like to use ARC to program the robot.   Has anyone worked out how to wirelessly interface to an arduino with ARC?
USB
Digital 21
#10   — Edited
DJ, what about using a iotiny plus a IIC connected either to an arduino mega or PCA9685 to control the 5v servos. I can add a single voltage regulator for the 8 servos. This way I could use the servo tools in ARC to automate the legs.  How would I map the servos?
Yet another option.. I found this thread in an arduino Bluetooth communicton scheme to ARC.
#33 Feb 2019 Any for that board will work. They just create a virtual COM port in Windows, which you select in ARC.
could I just use a Bluetooth module on the mega work and connect the it ASAP serial port to the pc? Load the ARC mega firmware to the board and massage in the Bluetooth code?
