Wiring A 3.5mm Headphone Jack To The Ez-b
Wiring A 3.5Mm Headphone Jack To The Ez-B
Hello!
I decided that for my robot Dewy, I wanted to give him some more volume, as the tiny stock ez-b speaker is almost silent in the body.
To do this, I would like to wire a headphone jack to the ez-bs non-amplified port and then run a wired speaker to that port(Keeping in mind that the new speaker will be powered separately).
Looking at Dave's tutorial he doesn't really show how the headphone jack is attached to the strip board(no diagrams or explanation from what I see), and so i'm asking for your help.
I've found some info regarding 3.5mm jacks:
My jack:
Any help is appreciated!:)
I would think so, otherwise it will play sounds as well... Worst case scenario you could always put it back in if you change your mind...
Thanks guys.
Richard, I thought there might be a possibility of an echo so I'll test it.
Rich, Thanks for the opinion.
technopro, do you still have the 3d printed case? Do you want a real case?
I do have the 3d printed case. All I really need is the camera shells, which I contacted Aslinn on. But if you were able to get me the molded case I would love it!
Following this, I have 2 3d print ez-bs and cameras. They look better outside the case than in though!
#15
i'll let aislinn know that you'll also get molded case as well
