Wiring For Roli
I got my Roli a few days ago and right track didn't work. I pulled apart the body and found the 2 wires for the track were not connected. I connected the wires incorrectly to begin with so that when I told the tracks to move forward they actually went backwards. I then reversed the wires and backward and forward commands worked correctly, but now left command turns right and right command goes left. Am I doing something wrong? What is the correct wiring configuration?
Hey Kurt! Welcome to the forum:) I would recommend following the tutorials for Roli to get him up and running - we put a lot of effort into them:D You can even keep track of your progress. To access the tutorials, either click on the Learn section from the above website menu or select the appropriate tutorial from the ARC software when it loads.
