Ok so in preparation for my V4 coming i'm buying last minute things. one thing that's needed is a way to convert the voltage from the board to 5 volts for sensors. This is what a came up with. Yes or no?
If I missed something let me know.
Smart Variable Watcher
— Efficient ARC Variable Watcher - lower CPU for large projects; slow initial array render but faster updates; shows name, type, value, length
I don't mind this DC Converter....
https://www.eachbuyer.com/5-30v-to-0-8-28v-dc-boost-buck-converter-5a-constant-current-volt-regulator-p238353.html?currency=USD&utm_source=google&utm_medium=CSE&utm_content=[Consumer+Electronics]&utm_campaign=[PLA]America%28EN%29&gclid=CKbd-fXKu74CFVQFMgodQggAYw
It's a cheap one and I believe it only truly has buck capability (no boost). It's small and gets the job done. It may take a little tinkering to get the trimpots adjusted correctly since there's no instructions. One trimpot sets the voltage and the other sets the current limit, from what I can tell. I got a couple of these and they seem to work fine.
Here is one I saw on eBay that says it can handle up to 12A.
DC-DC Adjustable Voltage CC CV Buck Converter 7-32V to 0.8-28V 12A 300W
Here is one I'm looking into for higher voltage servos.
(DC 12V/24V to 7.5V) (20A 150W) (STEP DOWN) DC/DC Power Converter Regulator
