Servo Recorder icon Servo Recorder — Record and replay named servo movements with adjustable speed/direction (-5 to +5), multiple recordings, ControlCommand triggers and status var Try it →
Wiring Specification For Extensions
Does any one know how to add extension wire to the servo wire connector without cutting or modifing the black clip end and does any one know if the replacement I2c port cable able to just clamp together like an extension wire or does it have to be cut and modified or can it use general same gage wire modded to it like servo extension wiring, cuz I trying to find a cheap way to finish my project on spare wires from old toy robots, so stage one of project omega can be completed and readied for programming. Any ideas?
For servo wires, the best and easiest solution would be to use servo extension cables available from the shop here, or from eBay/Amazon ect which can be picked up for just a few bucks for a multipack and simply plug in to each other. No cutting or modding required.
But to use existing wire you could cut in to the servo wire in half and join your salvaged wires in between both ends, and insulate the joins with heat shrink, terminal blocks, or wrap with electrical tape. Just make sure the salvaged wire is a similar gauge to the servo wires.
As for i2c I would take a little more care as it is quite fragile, and the slightest issue can lock the EZ-B needing you to power cycle it. The ribbon cables from the shop are female to female so can't be used as extention wires on their own.
But you can get yourself a pack of "four pin 2mm pitch male to male adapters" (seen above) which fit inbetween the two ribbon cables to make an extention, and wrap the join with electrical tape to make the connection extra secure. I wouldn't try anything else in regards to i2c cables, and this idea works, and works well with no issues.
Hope some of that helps.
Thank you very much, I figured it would be best to just by the servo extension cables but as far as the i2c cables when I had a felling that they would be really specific and I'm glad I asked I would hate to have locked up my ez-b the first time I used it, especially since I've worked so hard on getting omega built and ready. Thanks for your help you have been very helpful
Your more than welcome. If we are not sure on something, it's always good to ask whatever it is. Just to clarify, when I say EZ-B locking up, it's not as bad as it sounds. It's just that the EZ-B will stop receiving and giving commands and killing the power and powering it up again unlocks it and everything is all good again.
I had a bit of trouble a while back using jumper cables to extend an i2c cable for an RGB array and this caused problems for my project. Simply using another i2c ribbon and adapter solved the issue.
Good luck with your omega project. I look forward to seeing it when it's done.:)
Thank you I can't wait til he is complete either it's driving me nuts and bolts lol
so I was looking on amazon for the male to male adapter piece for the i2c cable and then I notice that the i2c cable its self has 6pin holes, does it have to be a 6pin male to male adapter for the female to female i2c cable or will the 4pin i2c male to male adapters work, because I was thinking that the 6pin would work with out adjustment or will it only work with the 4pin i2c male to male adapter work properly for it ?
The 6 pin wire (in your last photo) is for the EZ-B v4 camera only. So to answer the question the 6 pin adapter would be used with the 6 wire camera ribbon, and 4 pin adapter for the 4 wire i2c ribbon cable.;)
Can you provide a link to the six pin adapter you found on Amazon? I need one of those, and must be using the wrong search terms because I can't find it.
Lol, Alan, you bring up a good point. The 6 pin adapters with casing are like gold dust here in sunny (or should I say very windy) UK.
