Hey everyone.
Just making sure I'm correct on this, would this diagram be correct?
Thanks, Tech
HT16K33 Animator (8X8)
— Control for Adafruit 8x8 LED Matrix (HT16K33) via EZ-B v4 I2C; creates animations, supports module initialization and EZ-Script control.
Any ideas? Does everyone think I got duds? Or is there something related to the ADJ marking on them.
There is an adjustable version of the LM1084, and that is what you have.
https://www.ti.com/product/lm1084
"The LM1084 is available in an adjustable version, which can set the output voltage with only two external resistors. It is also available in three fixed voltages: 3.3V, 5.0V and 12.0V. The fixed versions intergrate the adjust resistors. "
My ability to read schematics is too out of practice to follow the diagram on that page, but apparently you use resisters to set the adjustable output.
@Tech... How Many do you need? I have some LM1084 (5V versions)... Just need your mailing address so I can mail them out to you....
Thanks Richard, but I'm not comfortable with giving out my mailing address. Thanks for the offer though. I guess I have to buy the right version this time.
No worries... I was going to give you them for free... If you want them email me at ryersonroofing(at)yahoo dot com
These look like the right ones, don't they?
JK_Part ebay
Yes, according to the ebay title, they would appear to be the ones you seek.
Hi @Technopro,
You could still use the adjustable version of the LM1084 if you have a few common resistor values and follow the pictured diagram:
Use a R2 value of 1kohm and an R1 value of 330ohms and it should give you a value of 5V. Equation is 1.25V(1 + R2/R1) = 1.25V(1+1000/330) = 5.04V
