Getrss icon Getrss — Fetch RSS via GetRSS command; populates $RSSSuccess, $RSSErrorMsg and arrays $RSSTitles, $RSSDescriptions, $RSSLinks, $RSSDates for scripts. Try it →
#170
@A.Bautista... Looks like you are connected to your ezb in WP mode.... While in WP mode you can't connect to the internet while connected to your ezb. Nomad is trying (like everyone else) to connect in client mode so he can be connected to both the ezb and internet at the same time... In other words he is going one step further than you in order to access the ezb's web server and change the settings. Again, this is so he can connect to the ezb in Client mode.... this is the preferred connection mode for the ezb....
@nomad... You're almost there... where it says SSID you enter the name of your home wifi network and below that where it says security key enter your wifi password... If you are successful after this step the ezb will reboot and enter client mode... The led light on the ezb will go from blue to green...
goodmorning rr
yes i try that but no succses.only on android it connect ,but not to webserver.
on the android its ez-b4xxx and it connects fast.here is the problem the phone, is not fast enough to look for the webserver 192.168.1.1
#172
Hey nomad, do you have some time to work on getting jd on your network with me?
#173
@d.cochran.... Thank God you're here dude... I can't offer Nomad anymore help... Do you think perhaps a session using Team Viewer might be the way to go? I know Alan has helped a fellow forum member that way....
My last ditch suggestion was for Nomad to find, buy, borrow or steal a Win 8 laptop and try again from the beginning....
#174
Yea, I think so. It just depends on the Internet speed. Also the issue is that his computer only has one network connection which is the one we need to use to connect to the v4 which will loose the connection to team viewer.
I think what I will do is try to connect with team viewer, and then get all of the information needed to make a video showing what needs to be done.
Nomad, let me know your availability today and I will see what we can get done.
hi guys.
d.cohran i have always time for you.
rr no money to by anything
#176
Cool, yesterday when I had to go, did you have the android connecting to the ezb ' s webserver using the browser on the android?
