Script icon Script — Multi-language ARC Script: build, run and debug Blockly, JavaScript, EZ-Script or Python with Intellisense, run/save/load and Roboscratch support Try it →
if nothing els works then it that the only option. i have here another acses point new one from linksys whit cd-rom is it possible to use two accses points?
#242
Nomad, I want to connect to your computer and look around but I cant read your language. can you send me a couple of screen shots?
I want to see your current network configuration on your pc when it is connected to your home network. I want to verify what you are putting in as the SSID for your home network when configuring the EZ-B V4.
#243
yes, it is possible to run many access points with different ssid's or the same ssid.
is the Linksys the one you are using now?
d.cohran i have skype patrick.dierckx19
the one am useing now is d-link cause that one was requested from telenet.
a,bautista thanks for helping.but lets us try one at the time
#248
@A.Bautista... Nomad has tried everything... that is, to the extent of his abilities... It's best we let d.cochran handle this as he has extensive knowledge in this area....
