Joystick (Direct Input) icon Joystick (Direct Input) — DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback. Try it →
Woot Parrot Ar 2.0 Drone Factory Refurbished
www.woot.com/offers/parrot-ar-drone-2-0-wi-fi-quadricopter-11?utm_source=Daily+Digest&utm_campaign=c98555c829-Daily+Digest+-+20150122+-+Woot&utm_medium=email&utm_term=0_c5ca76da11-c98555c829-302562417#tracked Woot Parrot AR 2.0 drone factory refurbished. Thought I would give it a try. I live in a rural area and this might be fun. Not sure of the range or flight time. Sounds like it might work with ARC, that is an added plus. If anyone has done a project, would like to share information, and tips, let me know. Thanks, Steve S
#25
Alan, I also purchased the adapter plate, but I have not successfully charged original or Turnigy battery with that adapter, on my Turnigy charger. I have successfully charged original and Turnigy batteries over a 20 times on the AR Drone charger. Have you had any different experience? Steve S
#26
I only charged one of them with the adapter but it worked fine with the EZ-B charger (using the 3s port). Charged a little slower than the Parrot charger. Not sure if the Parrot puts out more amps or if the battery was lower. I'll have to check the specs of the Parrot one (I know the EZ-B is 800 mah)
