Autonomous AI icon Autonomous AI — Autonomous AI robot skill with vision, speech, movement, animations, and self-directed task execution powered by LLMs. Try it →
Working With Nomad18.08 On Getting His Ez-B V4 On The Network
I am typing this for patrick because english is my primary language and I have been working with him.
He has a JD and another EZ-B v4. One of the two is able to connect to his network without any issue now, but one of them is having an issue connecting in AP mode. We cant connect via wifi from either of 2 computers to this one EZ-B v4.
There is one final piece of hardware that might make a difference, but I wont know until Friday. DJ and team, do you have any recommendations for me to try on the EZ-B V4? We have used the reset button multiple times with no good results. The EZ-B makes its announcement welcoming Patrick to the EZ-Robot revolution, and continues to flash blue.
Just so you know, Patrick does have Skype and TeamViewer installed and is familiar with how to use these.
Thank you in advance. David Cochran
i didn put holes in the ez-b4.only in the case.
@Nomad... By doing that you may have damaged the ezb itself... Make sure you make EZ Robot aware of your modification....
geez rr the ez-b4 was not in there when i made them.haha
am almost done whit the offset.i had to replace the mini servo's in the head and neck. they didn move.i notest not to use the pre-programmed off jd itself. the robot goes balistik when turn on and more whit connecting. so i made a new one.and all seems to be ok. i also notest jd head didn go far forwart.the screw was not far enough in. so i clean the edges and jd's head goes all the way forwart now. batt is charging now.then make the first poses. :D
Just to clarify, the holes that were put in were in the power base and not the V4. I may be wrong, but that is what I saw in the picture. Also, this is the one that came with the JD and not the one that came with the power base. The one that came with the power base is now powering JD.
He probably didn't do any damage, but most companies still don't like it when you modify their product while it's still under warranty....
d.cohran thats correct
if you use sound whithout the really tiny holes.it can damage the speaker. the base is diff build then the chest.no hole for the speaker.
rr you cant hardly see it.new base dont cost much.
#16
I understand, just wanted to state what the modification was and clear up that the modification was to a part that had nothing to do with the EZB in discussion.
BTW, the first thing I did with my EZB was modify much further than what Nomad did, to allow me to get rid of the base in my Wall-E. I am sure that there are others who have done the same, and I was fully aware that this mod would void the warranty. If any modifications had been done to any part of the one in question, I would have said "sorry dude, thats your issue now", but that isn't the case.
Anyway, Good luck nomad. Hopefully things get resolved for you with that one. I am glad you are enjoying your JD now.
